Should I bother going from DO 2.5" to 2.25" ?
Old 04-12-2001 | 05:07 PM
ELKTAGAZ's Avatar
Question Should I bother going from DO 2.5" to 2.25" ?
I have a Z33 Ravin Single 3" in, and Dual 2.5" NON-mandrel bent the Midas guy bent them himself, out. I did lose a bit of low end, I am wondering if I should bother going back and having him change the exits to dual 2.25" pipes? Wonder if you all think it will make any difference for me.
Thanks for helping!
J
Old: '97 f150 XL SC 4x4
NEW: 2001 F-150 XLT SC Flare 5.4L ORP 4X4 3.55
Az Beige
so far:
Westin Black Nerfs
Ravin Z-33 SI/DO
Aerovisors-off road
Bugflector II
AF-1
Duraliner(FORD)
Zaino
Extang Black Max
01L Tails
Old 04-13-2001 | 10:11 PM
dynoburt's Avatar
Post
Hi Elktagaz.
Believe it or not i just went yesterday to get a Ravin Z-55 SI/DO installed.
I also have the 3/ 2-2.5 configuration and from what i read on different sites ,i was expecting some low end torque loss.So I ask the guy at the Midas shop to reduce the exits to 2.25.He was not sure if it was a good idea but i was ready to assume the risk.(Which risk !).Actually i don't have the K/N FIPK and i can not say that there is a big difference in the hp/torque thing.More than that,i have only 105 miles on it.I guess It will probably get better with less restriction on the air admission and even better with a super chip.Those things are the next to come.
For now, the soud is music to me.
I'M not sure if the Z-33 are not enough "restrictive" but if you really want your low end torque back,it looks like you have to go SI/SO like Gibson does there system. May be the Z-77. I choose Ravin for the sound and i'll try to manage something to get the best of it.
Another thing! The Ravin on my truck is exiting before the rear wheel.(lightning style).i like that but i'm not sure about the effects.
So like they said: Just my 2 cents...
Take care!
---------------------------------------------- 2001 F-150 XLT Flareside Ext. cab. 2x4
- 4.6L / aut. 3.08 diff.
- Island blue/ dark graphite int. 60/40
- Factory AM/FM / cass./ 6 CD changer
- Duraliner
Mods:
- Ravin Z-55 SI/DO lightning style
- Black max tonno cover
- Magnum bug deflector
to come:
- K/N FIPK
- 255/65/16 tires
Old 04-16-2001 | 08:45 PM
ELKTAGAZ's Avatar
Post
dynoburt,
Thanks for the info! Sounds like youve got the setup. I may go and check with midas again and see what it would cost to go 2.25" out. The Z33 sounds great so I'd like to stick with it. Thanks again for the advice.
J
Quick Reply: Should I bother going from DO 2.5" to 2.25" ?
