2 ohm restistors???
2 ohm restistors???
i was thinking about getting rid of my cats and i heard of MIL eliminators but i also heard that 2ohm restistors is cheaper and does the same thing, so i dont get a check engine light.
where would i find 2 ohm restistors at? and how do i go about instaling it?
Also will it do any harm to my truck by removing the cats?
It has been proven that our cats flow very well, and removing them only picks up a few HP at the very top of the RPM range. It is a violation of federal emission laws to remove them. You will see a bigger increase in performance with a cat back system. IMHO, the best setup would be a dual exhaust system with x-pipe with a single high flow cat on each side. Check your local laws before you make any changes.
Re: 2 ohm restistors???
As to the harm done.....it shouldn't harm your truck to remove the cats, though you'll likely lose some low-end torque.
Personally.....I'd either invest in a high-flow set of cats, or simply remove the mufflers.
