F-150 rusted exhaust studs@manifolds
Had the same problem on mine. Did a temporary fix last Christmas (because, well, its too damn cold in Buffalo to do a real fix). My problem was that the bolts on the flange at the bottom of the manifold had rusted out. A special clamp is sold just for this purpose. Similar to a C-clamp, but one arm has almost like a pin to go into the hole and the other has a cup to fit over the stud. The pin can be swapped out and you can use two cups if the stud is coming out at both ends. Tighten er up, and problem solved.
It wouldnt work for the studs at the block, but on the flange where it goes back towards the rest of the exhaust system it worked perfectly.
i would go ahead and fix it before they get real bad. I bought a set of pacestter shorties from summit for a good price (oround 200) and a set of felpro gaskets. i also had to buy a set of damaged bolt removers from sears. (about $40). it took about 6 hours. a little agravating of a job but it fixed the noises i had coming from my engine bay.
