Cherry Bomb question
The last couple of times I have been crawling under my F-150, I have taken in what all is down there. Prior owner had the exhaust after the cats removed and a Cherry bomb muffler put on with a Y pipe following it into duals out the rear end. Makes for a nice low dull growl...not really that loud at all.
Now, I have seen these cherry bombs for sale in automotive stores and they come in various lengths. Is there any difference in the various lengths...or are they just built that way for application?
Second question....I have noticed that the low end start on my new truck compared to my old F-150 (both 5.4....1st one was stock) is a slightly more hesitant.....could this be a cause of the more "flow thru" of the cherry bomb?
Thanks in advance.
Steve
Thanks in advance.
Steve
Too much backpressure kills low end as well as too little. True flow through designs like the Magnaflow build torque at all RPMs because of a lack of backpressure. The Cherrybomb is choking your truck. I'd go for a performance muffler of some kind. It will allow you to keep the duals if you go with SI/DO.
