Power losses
Power losses
So I've been reading around on various forums and I've noticed something that is pretty common. People have a tendancy to say "if you install that muffler that way, you lose horsepower and torque or both." Nobody ever has any data on this, its usually just "this one friend of mine dynoed his before and after" or "a friend of mine owns a muffler shop and this is what he says".
To me common sense dictates that the less resistance to flow, then the engine has to use less horsepower to expel the exhaust out the tailpipes therefore making more horsepower at your disposal. I understand that if you go to the extreme and have no backpressure it can in fact be harmful and have negative effect on horsepower, however this really can't be achieved with a simple swap of mufflers can it? It doesn't make sense, there really isn't that significant of a change in flow properties.
So I set out the challenge to anybody to prove me wrong. Show me numbers, before and after an exhaust setup.
I've never dyno'd my truck, but after the exhaust install, and according to my Edge, I picked up 7/10's 0-60. I verified this with 4 different runs. As far as the numbers, I'd love to see dyno sheets as well, not just peak numbers. You can hack the exhaust off and gain peak numbers, but you'll lose torque most everywhere else....
Originally Posted by chester8420
Think about it this way... If it was better overall to change the diameter of pipes, or put hi flow cats, then ford would have done it from the factory. Some people are looking for increased torque, some for faster 0-60 times, some for max hp. It's according to your needs as to what you want to do to your truck. I, personally don't think that ANY exhaust system helps enough to justify the cost. If simple things like hi flow cats helped gas mileage while increasing performance, don't you think Ford would have put them on from the factory?!
On the other side of the coin is these items will add power depending on application. Alot of them aren't gaining power through the acctual muffler but more through the piping. If you look at your factory exhaust piping any bend in the system is crimped. So in that spot you go from a 2 1/4" ID pipe down to sometimes as low as a 1" ID pipe. Aftermarket systems are mandrel bent, so even in the bends you still have 2 1/4" pipes. Welding in a Flowmaster will give you a better sound but you still have to contend with the bent up piping so the gains will be minimal. A high flow cat will reduce some back pressure freeing up some of the power it takes to push the burnt fuel out, but it still is a cat so even though it flows better than stock it isn't flowing as good as a straight pipe.
Another thing to look at is the car is built to run with the current exhaust system, once you start changing it, in turn it will change the way the car runs. Alot of times exhaust modifications will cause the car to run rich which will reduce some of the power you might have gained from the system almost canceling them out. Now if you put the exhaust system on then tune the car on a dyno adjusting the a/f ratio then you will see the gains you are getting from it.
If you run too big of an exhaust system what people commonly refer to as backpressure will be lost, what this is is a pressure difference between the inside of the cyl. and the headers. The pressure difference sucks the spent gasses out of the cyl and in turn sucks in the new air charge from the intake. If you loose this pressure difference by running too big of an exhaust setup you will not get all of the spent gas out. So now you have some bad air so to speak taking up room that otherswise could have been filled with a fresh air charge. Not only do you now have unburnable air taking up room in the cyl that left over air is also hot which heats up the new intake charge creating even less power.
A big free flowing exhaust will increase your peak hp numbers up top as scavengin isn't as important in the higher RPM's but you will loose gobbs of torque below the curve. Example I had a Grand Prix GTP that I put a ture dual exhaust on from the headers back. 2 1/4" pipe all the way back to the mufflers. Since I was supercharged and the supercharger forced the air in and the old air out scavenging wasn't that big of a deal to my car. I picked up almost 30rwhp. A guy I know who had a non s/c GT tried the same setup, he gained 5hp peak to peak but lost as much as 20lbft of torque under the curve because the exhaust system was too big for his application.
[QUOTE=01TruBluGT]he gained 5hp peak to peak but lost as much as 20lbft of torque under the curve[QUOTE]
5 hp is an insignifigant ammount when you're talking about a pickup truck. That 5 hp is almost immeasurable. From day to day, your truck gains and looses 5 hp just from changing atmospheric conditions. You're talking about a waste of time and money. If you want to irritate everybody with a loud exhaust system, fine. But think of it this way.. If Neal was to put a muffler on his truck, would he loose 40 hp? I don't think so! People come on this site for advice about their trucks and I think that they recieve a lot of bull crap about increasing hp and gas mileage. It just doesn't make that much of a difference!!!
NOW. If you're racing your truck, then by all means, 5hp here and there may be signifigant. If you drive your truck back and forth to work or school, 5 hp is useless.
I don't want anybody to get offended at me. I just come on this site and see kids soaking up everything that is said here. They leave this site and go buy new exhaust, cold air intakes (which are stupid cause they take hot air from under the hood!!), underdrive pulleys, e-fans, and amsoil oil cause it will make their truck last longer and give them better fuel mileage.
People come on this site for advice about their trucks and I think that they receive a lot of bull crap about increasing hp and gas mileage. It just doesn't make that much of a difference!!!
NOW. If you're racing your truck, then by all means, 5hp here and there may be significant. If you drive your truck back and forth to work or school, 5 hp is useless.
"If you're racing your truck, then by all means, 5hp here and there may be significant."
Well if it would be significant for racing why would it not be on the street. 5 here 10 there, another 5 or 6 here, after a few bolt ons you could add 20hp or so which you WILL notice. If I were to take your advice verbatim then I should only stick to mods that in themselves would give me enough to feel and make a difference.
I don't want anybody to get offended at me. I just come on this site and see kids soaking up everything that is said here. They leave this site and go buy new exhaust, cold air intakes (which are stupid cause they take hot air from under the hood!!), under drive pulleys, e-fans, and amsoil oil cause it will make their truck last longer and give them better fuel mileage.
I am pretty confused here...
It seems some of you are basically saying to add a freer flowing muffler/piping would actually decrease horsepower and torque. What it seems to me is that by adding a free flowing muffler and piping that you would decrease backpressure, which would in turn allow burnt gas to expel much easier, which would decrease strain on the engine, resulting in increases in torque and horsepower.
I do not have dyno evidence to back this up, but it seems some of the above posts insinuate that adding a freer flowing muffler (or system) will not make an engine perform better. If this is the case, why have so many dyno tested magazine articles and tv shows (Horsepower TV, Trucks) show contrary.
I personally do not think there is some huge conspiracy to sell mufflers and hurt performance and efficiency. The simple truth seems (again, I am not an expert) that Ford does not install free flowing mufflers due to several factors (demand for louder exhaust not being very significant, costs of said mufflers being high, and possibly regulations).
Exhaust systems don't help you a signifigant ammount to justify the cost. They do make your truck louder, and if it's what you want, then go for it. If you don't believe me about how much it helps, just run your truck in a drag strip, and then unbolt your exhaust system, and run it again. It won't help your times. I tried it.
What I meant by racing, was that if your truck is putting out 700 hp, well, then the small diameter pipe and muffler might be a bit restrictive. But with a relatively unmodified engine, it's not going to be that much.
I added a Volant SISO for looks as well as sound... Didn't consider performance #'s for that purchase since I was installing an Edge Advantage at the same time.
Here is a post on my (good) experience with the Volant Cat Back.
https://www.f150online.com/forums/sh...d.php?t=236748
