Should I weld everything or clamp?
Thanks for all the advise. I have a local muffler shop that is a certified Magnaflow installer that is going to do the work. I have a towing hitch so there is a small modification that will need to be done and they have the right hangers for my duel rear exit pipes. So stainless clamp at the factory and weld the rest......Blue
its easy to install dual exhaust system just make sure it is allined properly and weld it up all the way back i remend welding it to the factory cats so exhaust gasses dont leak and you will know if they do the gases will give quite the headache i didnt weld my tips in cause i want to change them later
