Bosch Oxygen sensors Vs. Motorcraft
Old 11-16-2006, 01:34 PM
Maya'sDad's Avatar
Question Bosch Oxygen sensors Vs. Motorcraft
Check Engine light ON.
OBD2 said replace O2 sensors.
Replaced with 2 Bosch. Reset OBD2.
Check Engine Light came back on.
Dealer says need to use Motorcraft O2 sensors or Computer will detect a fault.
Can anyone verify this?
Old 11-16-2006, 02:43 PM
SmoothSL's Avatar
Did it say replace the sensor or that they were out of spec meaning you are running too lean or rich....
And I say bull to the Dealer..
Old 11-16-2006, 03:29 PM
ammoeater's Avatar
I thought Motorcraft O2's are Bosch?
Old 11-16-2006, 03:31 PM
SmoothSL's Avatar
Yeah, I'm betting most manufactures O2's are Bosch!
Old 11-16-2006, 03:46 PM
tex_n's Avatar
Dealer is full of it! On another note, very rarely do O2 sensors go out. Most likely something is occuring within the engine that makes the computer think that an O2 sensor is bad. Post the actual trouble code number here, and someone will come along with a possible solution. Also post year and engine, etc.
Old 11-16-2006, 03:57 PM
Maya'sDad's Avatar
2001 4.2 6 cyl. 114k miles. I have read a few posts here and I'm wondering if:
The K&N filter has fouled the Mass Air Sensor.
It's true that O2 sensors are good for 70k miles.
There is a vacuum leak somewhere- though the truck runs fine
Old 11-19-2006, 11:39 AM
Maya'sDad's Avatar
Left bank, right bank, running lean.
Old 11-19-2006, 11:40 AM
Maya'sDad's Avatar
Cleaned MAS with brake cleaner.I have a K&N oiled filter. Lets' see if that resolves the problem
Old 11-19-2006, 09:57 PM
Rick1067's Avatar
Same Problem
Maya's Dad
I have a 97 4X4 Lariat 3 door Flareside with a 4.6 that has the same problem. After installing a K&N filter, two codes poped up which were 0153 and 1151. I replaced the MAS and the O2 Sensor cleared the codes and they came back up. I am going to buy a regular air filter tomorrow to see if that clears the problem will let you know.
Old 11-20-2006, 03:00 PM
KALIF150's Avatar
Yes there is a vacume leak. Kinda common with the 4.2 f150 &e150 and 3.8l in the windstars. The bolts that secure the upper plenum to the lower manifold develop a vacume leak and need to be replaced. I've done quite a few sets and if cures it every time. (Been working at the dealership for 10 years).
Old 11-20-2006, 05:17 PM
csonka
Guest
Posts: n/a
What is this vacume leak you speak of?
Old 11-21-2006, 09:35 AM
Maya'sDad's Avatar
Eh...? Are you talking about the the plenum for the intake on top of the block. Can you be more specific. What bolts? Gasket replacement?
Old 11-21-2006, 10:17 AM
Maya'sDad's Avatar
Rick1067- Thanks!
Old 11-22-2006, 03:31 PM
Maya'sDad's Avatar
Checked for vacuum leak at plenum and various hoses, found none. Replaced Mass Air Flow- Light still on!
Will replace fuel filter- bet light remains on. Every time I see that light I see "Owner is a schmuck"
Old 11-22-2006, 07:41 PM
Rick1067's Avatar
Owner is a schmuck Light
Went Back to the regular filter gave it a couple of days and the "Owner is a schmuck" Light came back on. The Manager at the local Auto Zone said he had the same problem with his Chevy and took it to the shop. The mechanic found where a couple of wires from the computer were the sheaths were cracked and condinsation built up on the wires.
I do not think this is the problem though.
Quick Reply: Bosch Oxygen sensors Vs. Motorcraft
