turn downs the wrong way to go?
Basically some people are afraid to run open headers or even exhaust dumped at the axle because they will crack a valve with that. What happens is the exhaust can get hot (we're talking about thousands of little explosions happening in your engine and a lot of that heat is leaving through the exhaust port into your headers) and the air outside can be cold and when you get a very hot metal and get it against something very cold (in this case the air outside) it can crack (I broke a glass fresh out of the dishwasher like that). But that is only with no headers or shorty headers. Go to a dragstrip and you will see a lot of cars running only long tube headers and those top fuelers run a short length of pipe and they are fine because the length of tubing heats up and keeps the air right next to the engine hot and gradually cools down.
In short, like built54 said, you are fine. I am running a turndown with a 40 flow and ran that on my old ranchero (along with pretty much everyone I knew) with no problems.
