Magnaflow 16612 ordered!
#31
Originally Posted by kd4crs
Zig, Your tip is where I want mine to be. Mine is all the way up at the fender opening. I just don't see how flipping the muffler will move my tip to the rear though. Thanks very much for the pictures.
I can't figure out why yours would end up in a different location than mine. Do you have any pictures?
#32
Originally Posted by 02XLT
All of your hangers lined up without having to bend or anything right? That is strange that you are having an issue. Did you use the correct inlet pipe? I think there was an 18inch or 24inch pipe you use depending on model year? Just asking I doubt you could put the wrong one on due to hanger locations...
Also now that it is daylight and I can see my truck better, my tailpipe is right at the end of the fender well. On the FX4 we have the lip molding on the wheel wells. My tip it right under the molding, not in the wheel well mind you, but right under the molding. It looks fine though... So it appears my location is the same as yours??
-Brian
-Brian
#34
I am getting ready to order from Performance Peddler, but want to make sure I get the right kit. I have a 2005 FX4 Super Cab Flareside. The kit I want is the 16614, right? All the sites say this is for Ext. Cab/Crew Cab, short bed. Is the short bed the 6.5 or 5.5? If it will fit a Screw with the 5.5, it should fit my Scab with the 6.5 right?
Anybody have this setup on a truck like mine? I don't want to order the wrong kit.
#35
16614 if you want dual exhaust, 16613 for SI/SO like we have...
-Brian
#37
#39
Here is a pic of the tip. Others are in my gallery. See what I mean? Too close to mount mudguards.
Before
After
#40
#41
Zig, now that you mention it, the last hanger is twisted about 20 degrees in the bushing. Maybe flipping the muffler is the answer. I just hate to tear it all apart and then have it not make a difference or worse yet, have it be even more poorly positioned.
How long has your system been installed?
#42
#44
I got curious after re-reading the instructions and looking at everything, so I called Magnaflow's technical support number and got to speak to a nice guy who told me the correct orientation for the muffler on this system is VERTICAL with the outlet at the bottom! I would never have thought to try that. I am going out as soon as I change clothes (and the truck cools down) and loosen it all up and give that a try. Wish me luck.
#45
-Brian
