New S&B arrived today
I just put mine on the other day. I was pretty happy with it overall. It does have some drone under acceleration but it wasn't that bad. I left the battery disconnected for about an hour at first and got no CEL the first day I had it installed. The next day I drove the truck though and got a CEL. I called S&B. They said to disconnect the battery again. I left it unhooked for three hours. Has been three days now and no CEL. Hope I don't get one again or I might be returning mine also. I would think that if it has been ok now for three days then it should be ok. That was my only compliant though. Nice looking kit and install wasn't to hard.
Question...
Has anyone found dyno results for this? I did come across some dyno results, I think it was from the 'most powerful intake'... one source was just MAX numeric data, and one graph that starts at 3500 rpm....
I (like everyone else probably) would like to see a dyno graph from off idle.... for me... the power it makes at 2200 rpm is WAY more important than what it makes at 5300 rpm.
It would be great to get all the dyno results together in one thread.... not sure how relevant my question is... as I have an 5.4l 2v...
undeaddemon
Getting dynos made from idle to redline can easily be done with manual transmission vehicles, however, most trucks have automatics. Dynos are usually done around 3rd gear and when you floor it, the tranny drops into second and thus about 3500 rpm plus.
So unless the dyno shop can get a hold of a manual tranny truck, your wait may be long to see a dyno that gives meaningful data starting at 2200 rpm.
Originally Posted by torqueaholic
undeaddemon
Though it may be unlikely, I still would like the info!
They tell you to conect the oval tubes first and then push onto the TB. I noticed on mine the bushing onto the TB is a little up on the back side. I was wondering if this is normal. Almost like the TB is angled back and the bushing is going on straihght down. I am all for a little noise, but I dont know if mine is normal or if something is vibrating, but when i just get on it a little I get a pretty loud noise from it. Anyone else with the S&B please tell me if this is normal before I go crazy trying to fix it. Thanks.
