1997 4.6L Exhaust Manifold Stud & Nut / Collector
Vehicle: 1997 F150
Motor: V8 4.6L
4WD XL Extended Cab
Description of Problem: Loud exhaust coming from directly outside the exhaust manifold. Occasionally the noise ceases after driving for a while, I'm unsure whether or not this is due to it heating up and making a better seal or if it just "falls" back into place.
Question: Does the stock exhaust have a collector / donut gasket?
I'm trying to replace the connector from the exhaust manifold to the exhaust pipe with an Exhaust Manifold Stud & Nut Kit and am unsure whether or not it requires a collector / donut gasket as well?
Has anyone experienced similar problems and or replaced this part before?
Any tips before I proceed?
Motor: V8 4.6L
4WD XL Extended Cab
Originally Posted by jjmIII
Well, your probably ready for new manifolds and studs. They are known to rust-out and leak. Do a search on "manifolds" and you'll read plenty.
i have a 97 4.6. there is no donut gasket for the stock manifolds.your manifolds might be ok. you might just have a few broken studs. if you plan on keeping the truck you can get new manifolds at rockauto.com for like 60$.i had to replace my passenger side. it was rusted bad. bolts were pretty much gone.
