Cats
Cats
So I called the muffler shop to get an estimate on them installing a muffler and two high flow cats. Well, the guy tells me that I need 4 high flow cats because there are 4 o2 sensors, so it would be illegal for me to do just the two. Well I know you can do the two but I need help to explain to the guy why I only need two. So if someone could help me with that. The trucks an 02.
if its like my 98 there should be two sensors on each side with one before the 2 cats and one after, i didnt think there was on in them or did they change the newer ones. but if its like mine he just needs to cut the old cats and and weld the new ones in with a little extra pipe inbetween the two sensors on each side.
Scott
Scott
Originally Posted by glc
Find a different shop that's willing to risk EPA scrutiny. What you want to do is technically illegal.
You may have to look around for someone to do it.
Good luck,it's a great mod!!!
Phil
Originally Posted by Brian 5.4
Do you get much sound on a 2v 5.4 doing a setup like this? What is the main reason behind this mod?
Phil
