A couple of AF1 pics
Originally Posted by TexEdition
It's 3", my photog skills ain't all that.. lol..
Pipe size is deceiving - the engine compartment is huge, hence it's difficult to reference the size of stuff in there... plus the filter itself is real big too...
Tex - your pictures look great - no worries on your skills there. However you need to work on engine compartment detailing a little J/K !
Cheers
Bubba
Cheers
Bubba
Cheers
Bubba
Hmm.. I see the difference.. Mine's an 05 and 4.6L.. the wiring is the MAF connection.. not sure why mine would have the connectors requiring the ring clamps when yours doesn't??
plus my filter looks longer / narrower.. must just be the difference in engines??
wxscpo, did you have any trouble getting the two studs on the heat shield to seat down into the rubber grommets?.. I thought I had 'em seated completly but heard a vibration at idle today and looked and both had worked up and loose.. now I can tell that I'm not getting them ALL the way through the grommets.. Think maybe I'll need to remove the filter and shield, apply a little silicone grease and use channel locks to squeeze 'em thru..
