Sound
Sound
Hey guys, another exhaust question for y'all. I was seriously debating on getting a set of Cherry Bomb Glass Packs, but I work around horses a lot, and have a feeling that it would scare the daylights out of them, causing way more problems than its worth. Anyone else have past experiences with this in any way? If not the dual cherry bomb's I was thinking dual Magnaflows, does anyone have a recomendation for loud, and very throaty, but not rediculously loud, as I have heard that glasspacks will do? Otherwise those with glasspacks, is it seriously that loud?
~Phil
~Phil
I run true duals straights with an x pipe and have 2 less cats than you, and I have no problems with scaring horses. I am around them daily and have no problems, horses are pretty good about noises like that though. BTW I hate glassepacks they pop way to much for my taste, I would say magnaflow is probably more what you are looking for.
Blake
Blake
Sweet, I appreciate the response, no glasspacks it is then, I too do not like the popping sound. The last thing I wanted to do was get fired from the barn for having a truck thats too loud, and one of the horses flipped, everyone around the barn uses stock exhaust so I wasn't sure how they would react (should have guessed when the tractor and gator start up, its louder than anything else lol). But since I am gonna go Magnaflow, what kind do y'all recomend?
~Phil
~Phil
So you would go with one single muffler to handle both? I was thinking of just getting two mufflers, although more extensive to create, I think it would sound better. I dunno, I'm lookin' for help I guess, is that what others would recomend as well, a DIDO muffler, instead of two SISO mufflers to create a true dual exhaust?
~Phil
~Phil
They all have an x pipe built in already? Is sound changed in any way using a DI/DO? If I am getting it custom done, I might as well get two if it will improve sound, but if it would make no difference I would definately go DI/DO it would probably bump cost a little bit as well them not havin' to put in two mufflers. Thanks for the help!!
~Phil
~Phil
