SIDO or true duels?
Exhaust
I run the true duals on my 2000F-150.I cut the "Y",installed 2 high flow cats,into a Bassani X pipe,into 2 50 Delta flow FM's,the pipes are run out the back and dump in front of the rear bumper,no tips.This is an excellent setup for sound,performance and I believe I picked up a mile or two in fuel economy.The duals and the X pipe help balance the backpressure and scavange the exhaust.My truck runs and sound great,IMO,go w/ the dual setup.I hope this helped,good luck w/ your exhaust.
In my experience preference and price is the only realistic difference aside from manufacturer (Unless your doing headers too (longtubes only; ask BUILT54)). And GO FOR LOUD cause you'll want it to be louder after a while anyway.
Make sure you read as many of these forums as you can before you spend your dollars.
It's all personal preference, and what is in your budget. I have had Mag SIDO on both my F150's and could not be happier. A guy I used to work with had true duals and they did sound sweet! I prefer a milder tone, but it still sounds like a V8. And when you couple an exhaust system with an open element cold air intake, it will sound even better!
