07 5.4 Intake System
I wanted to see if anyone has put a intake sytem on the 07 5.4 f-150, the local ford dealer does not recommend one . they say you get water and all types of stuff sucked up. is this true? I have put dual's on also the 2.5 kit with 33-12-50's . I just wanted a little boost, and better responce on the pedal. I dont want to go to a tuner. they sound more of a problem more than anything else. also what brands does evreyone think would be a good air intake? thanks
A tuner will net you far more gains than any intake and exhaust combined. It is also the ONLY way to fix your throttle response in a drive-by-wire truck.
And if you increase your tire diameter, how are you going to correct your speedo & shift points?
If you think tuners are a hassle, you haven't researched enough, because that is simply not true.
BTW - my intake recommendation: 3" AF1 ( without a custom tune) or 3.5" AF1 ( with a custom tune).
I have the 3" AF1 and just installed my custom tunes a couple days ago. It was absolutly no hassels. The difference is worth the wait! Changing from custom back to stock takes only a few minutes! If you rode in my truck or anyone else with custom tunes you would change your mind quicker than my throtle responce which is pretty quick these days ! i went with Troyer because of the personal attention he gives to this site which equals great customer service in my book!
Shane
Shane
