Exhaust Leak???
Get the Felpro gaskets - re- tighten the manifolds from the center out.
You could also loosen the manifold bolts and re- tighten from the center out, that might be enough pinch it off without a gasket replacement.
You'll need a 13mm wrench .. If you loosen your tranny support (18mm) - you'll have better luck..
