Exhaust Leak???
Exhaust Leak???
I have an annoying exhaust leak sound that sounds like it is coming from the passenger side. I have checked all of the spark plugs fearing that I had one loose, but they were all good and tight. I have also looked around the exhaust manifold at the head and collector and can see no evidence of any type of leak. There is a small leak where the magnaflow slips on to the factory Y pipe. Would this get loud enough to be heard plainly inside the cabin while accelerating?
Follow Up to Exhaust Leak
I have already checked the manifold bolts and they all look nearly new with none broken off. I have no black soot anywhere near the manifold or collector to indicate a leak. I would still swear that it is an exhaust leak. It is not really noticable until I accelerate during normal driving. I will find it eventually I guess.
i have the same problem. I am almost embarassed when i ride by buildings cause of the sound that bounces off the walls. All i hear is air when i hit the gas. But i shouldnt have to worry about that much longer. I am getting true duals next week, and i will check and make sure the spark plugs are tight as well
It could be your joint with your magnaflow, my brother's exhaust had a small leak at a junction and was extremely annoying. He took it back to the shop and they reworked it and so far all is good. It was more of a whooshy sound as opposed to the ticking when it was his manifold studs however.
Same Problem
I had the same problem on my 04 FX4 Screw. I also checked the bolts and they were good. I found a "redneck" check online. Attach (with duct tape) your shop-vac to your exhaust tip and place your shop-vac on blower setting. The pressure inside the exhaust system will start to leak (without the motor running). I used a soapy solution to find the leak. My exhaust manifold gasket was leaking on the passenger side. Sounds hokie, but the blower trick worked. I had to have the wife hold the hose though, otherwise the pressure would blow the hose off of the exhaust tip.
Lets try to figure this out, or I'm trading up for a used avalanche!!
Definitely the manifold
Well, I tried the squirt bottle full of soapy water trick and there they were. Bubbles by the hundreds. Looked like a tiny little bubble blowing machine gone berzerk. I guess I will do my research and figure out my next move (fix the leak, install shortys, or go long tube). Money (or lack thereof) is a factor here so, the long tubes are probably not an option at over $1000. Everything I have read tells me that shortys don't give you that much power if any. That leads me to believe that I will go buy the bolts, gaskets (felpro) and just fix what I already have.
Anybody out there with any other options (other than just let it leak) please let me know about them.
Ok, So i have the same problem on my passenger side. What steps do I need to take to fix this? As in parts. I figured i would take my passenger front wheel off along with the plastic gaurd above the wheel. What do i do from there? Im assuming it's my exhaust manifold. Ill try the bubbles/vacume trick. How much are the gaskets usually?
