Dynomax Mufflers
Dynomax Mufflers
i was looking into the dynomax bullets, but my current setup is a SI/DO and they only make SI/SO for the bullets and i want to keep my dual tips. i found the dynomax ultra flow welded muffler that is SI/DO and the exact same size as my super44 so it would fit perfectly as a replacement, but i dont think its going to give me the same loud sound as the flowmaster, and i dont want to lose any sound with a muffler swap. Will it not be as loud?? (if it is as loud, ill swap)
or......
Could i run the bullet SI/SO then have a Y-pipe right after the muffler into my dual tips? or would that give me bad airflow?? (the Y-pipe would also have to go from a single 3" to dual 2.5", is it possible??)
or......
Originally Posted by Jwool15
Sparky.. If he goes that route he mights as well go true duals. I strongly suggest doing that and getting an X pipe. You will love it.
If the ultra flw welded SIDO will put out as much sounds as my super44 ill do that, but if it wouldnt then maybe weld in a bullet and run a Y-pipe after it into my dual tips. id love true duals but my current system has 3" and 2.5" pipes and id have to replace all of them with 2.25" and its just more $ to spend.
what should i do??
what should i do??
I wish I could help you on the y-pipe after the muffler theory,but I have no idea how loud that would be?
but I can say that if you have longtube headers with a x-pipe and bullets your friends will be doing this
i got quoted$200 for tru dual system with 3inch stainless piping all the way back with x pipe and mufflers.. not a bad deal if you ask me.
im seriously considering this.
Originally Posted by SFM
Just wondering.. why are you getting rid of the Super44? loss of torque?
nothing wrong with the super44, just want to try other stuff. (reason i have a hard time deciding is because im so attached to the sound the super44 puts out, its so sweet i dont want to switch and then be disappointed)
WHOA, not a supplier endorser but, Dyno Bullets should be $35-$38 each from Jeg's, not $60. Just tryin to save ya some $ . I personally have ran the x-pipe, w/ 2.5" pipe, Dyno Bullets 16" long, & turndowns after the axle. Great set-up financially, accoustically, & performance. The only thing that'll cost ya is the x-pipe. It's worth it. As soon as I get my TTL paid for I'll be doin the same thing.
