System suggestions
System suggestions
I think I should have make my username Clueless. Anyway, I'm sure I am going to change the exhaust on a 2002 Supercrew 5.4. I like the Dynomax Bullet mufflers. But from there back to the engine, could someone reccommend a setup for horsepower gains? I don't understand x pipes,catback,etc. You wouldn't have to go into detail,just maybe some things that I could pick from. Thank you.
well your whole mid pip sections really arent going to get huge gains unless you get a shop to do mandrel bending for you. Mandrel bending is where the pipe is bent smooth, instead of kinking around the turns.
you can do an X or H pipe. the X pipe will be better for top end power, and louder idle. the H pipe will have more low end torque, and quieter idle.
Other then that, you shouldnt need to touch the cats unless you want to go with highflow cats.
-Patrick
-Patrick
