Airraid CAI any good ?
Originally Posted by UtahFX4
Where did you order the Roush ?
I went to: http://store.roushperformance.com/detail.aspx?ID=777 and conducted a "Dealer Search". I purchased it from a local Ford Dealership for $285.00. Cheapest place that I found anywhere... It was/is actually cheaper than the Airaid. I know that the Airraid is one of two CAI's that will not throw a code, and more importantly, will not lean out... As mentioned, The Roush is the Airraid, but I like the Roush badging better. I also found it at: http://www.woodhousestore.com for $265.00, but with $30.00 S&H, plus tax, it was still cheaper to go to the local Ford Roush Dealership. I hope that this helps.
just my experiences with this intake, I have an airaid intake kit ( looks exactly same as the roush ) and ran it on the 05 and 06. Never threw a cel in either truck with it. The 05 had borla exhaust, 06 has magnaflows. When running stock tuning on both, as well as one on my bro's 05, with stock exhaust, during easy acceleration, it made an annoying drone at 1800 rpm on all of em. That's 3 trucks, all with 5.4's, same drone. Tuner with Troyer tunes got rid of drone on my two trucks, bro's Edge on lvl 3 did not. Have an AF1 w/ 3.5" intake now and no drone. Perhaps the stainless tubes versus the plastic does basically stop this. Could be real annoying when towing as that is basically crusing rpm's. It's back in the box now.
Here is my assessment of the Roush/Airaid that I just installed on my 5.4 FX4-
Installation: very easy... took about 45 minutes. OEM-like fit and finish. Only modification neccessary was that I had to push the brake lines down a little. Everything else was easy by following the well written(w/photos) instructions.
Performance: There is definitely some gain, a tune would really help this set-up, but I wasn't looking for a tune right now. I'd say there is at least 10-15 hp gains, more importantly, it reduced the throttle lag.
Sound: Really have not noticed much of a change. My 14" muffler/dual Magnaflows must be drowning it out. Actually, it help the drone with my Magnaflows. The exhaust seems more "tuned". I have not heard any whistling, droning, etc., from under the hood. Just the swishing/sucking sound with the hood open.
Codes/Lean: None
Conclusion: IMO well worth the money. Looks good, sounds good, and feels good. My two months of research paid off. If you're looking for a good non-tune intake, this is definitely the route to go; with the option of adding a tune later.
Originally Posted by SteelTownStang
If the tune from Troyer elimated the drone, then why is it back in the box?
Good reason... I have had some experiences with tunes and intakes as I've had the "set-ups" on several other vehicles. To say that one CAI is "much" better than the others with regards to performance in definitely a misconception. Sure the quality will vary like everything else, but the amount of air going into the throttle body is similar yielding a nominal difference. A tune, from a reputable “tuner”, is the most important variable. Sure, Troyler is pushing the AF1, as he is a vender/distributor, and profits on mass sells... There is NOTHING wrong with it, except for the lack of partiality. Doug/BamaChips pushes JLT, Brent/Brenspeed pushes C&L, etc. All are quality tuners selling quality products with very similar results. My point is... if you put the AFI next to the Roush/Airaid, and both are tune properly, I guarantee the difference will be very minimal... definitely not worth putting a $300 CAI into a box for another $300 CAI. Nonetheless, it's cool either way. This topic is debated on countess forums for numerous vehicles. If you're happy, that's all that matters .
