Magnaflow set my truck on fire! AGAIN
Originally Posted by pmason718
ok cool. I didnt want to spend all that money and have to worry about my spare tire burning.
As long as there is clearance ( no contact) there are no issues. Except for extenuating factors, as noted here ....
No, RP.
There is no direct measurement of this parameter in these trucks. You'd need to add a pyro to do this. At it's extreme, the catalysts and the O2's may become compromised, and codes thrown at that point after the fact, over time.
It's worth noting that when custom tunes are R&D'd by you-know-who, this is exactly what he does as part of that process; both for perf and tow-specific tunes.
A few-plus Lightning and diesel owners pushing the envelope also mount EGT gauges for safety reasons - not for melting spares, but to ensure they are running within a margin of safety - since no other means of determining this condition exists while underway.
It's usually caused by tending lean at high loads. EGT's are yet another 'window' into how well/safely a vehicle is performing.
Note that I am NOT saying that this is the definitive reason here, only that, since it can be easily verified or dispelled as a possible cause, it should be investigated.
MGD, I know who and I don't even need a egt gauge to tell me that. Thinking back to when mine burned and learning some things, I agree with you and do believe a lean or slightly lean condition led to higher than normal temps in both these circumstances. At the time I ran a very questionable intake and won't even mention the tunes here (no one would know them anyway) but let's just say they should stick to 'stangs. However, the piping was pretty close to the spare. It's sort of embarrasingly stupid but I noticed mine being within about 1/2-inch of the spare when installed and I was unable to get it shifted much even after re-doing it back there. When bolted back up the piping just wanted to go back where it was which was very close. My spare did not shift. On some applications this just may be worth noting and is easily taken care of with a little pipe work. Maybe it also took a lean condition and obviously towing heavy.
Dang it! You must have some bad juju or something going on. I have towed our travel trailer to Holiday World and other destinations with my Edge on level 2 and my 16612 hasn't set anything on fire. Yet. Definitely need to measure the exhaust temps stock and on level 2 to see if there is a big difference. That may point you in the right direction to get to the bottom of this.
If I just buy the exhaust 16612 and that's it , will that be cool. I hear ppl talking about other item like troyer (I hope Im typing that correctly). Will I need that. Im just looking for a little sound thats all, but not loud.
Man this is crazy stuff. I've had my Magnaflow SI/DO system on for a year and 10k miles now. My driver's side tailpipe clears the spare by at least 2 inches and I've had no problems at all. I've towed a 25 ft travel trailer 500 miles with it twice this year also. I am on the stock tune though but I do think you should get a temp gun and check pipe temps.
