Another Roush Exhaust Thread
I heard back from Mike and he has indicated that the system will indeed work with the 6.5ft bed. It will cost a little bit extra and I assume that is due to the fact that some additional tubing would be included.
Just wanted to pass along this little tidbit of info in case anyone else was wondering.
Borla (Roush) makes really cool extensions for adjustability. Basically one pipe slides into another, then you band clamp it when it is properly adjusted. Atleast thats how my Mach 1 kit worked. So they will probably just include longer extensions.
If Roush is using this same type system, you may think about putting some lock tight on the band clamp screws or have the system welded after final adjustment. On the Mach 1 forum, a few people reported the screws loosening over time. FYI, my screws never loosened with nothing done. Had the system for about 1 year before I sold it for my 07 F150.
Originally Posted by miseroth
After reading through all of the threads on the Roush exhaust system, I am almost sold on this kit for my 2007 Screw 4x4. My question at this time is if this kit is available for my truck with the 6.5 foot bed?
Thanks!
Thanks!
Ford evidently makes adjustments in their factory exhaust such that the supercab and Supercrew both have the end of their pipes (where the Roush ties on) in the exact same location from the rear of the truck. The Roush kit fit right up without cutting any pipes. Go for it. See the other Roush Off Road posts. I have posted this kit WILL FIT the 6-1/2 Foot bed many many times.
Here's what the kit looks like...
Oh, and the rear exit photos in my gallery are of the Magnaflow 16614, not the Roush Off Road.
Originally Posted by Smokewagun
I think someone is tweaking your pickle. My system directions said it fit the Supercab AND both bed length Supercrews.
Definitely worth a follow up question to make sure.
Thanks!
I could be wrong in my assumption about the cost. I see that the system costs $430 on the website and the grand total that I was given was delievered to my door. I am not sure how much shipping/handling would be on this, but that very well may be what I was assuming was "extra".
Thanks!
Thanks!
https://www.f150online.com/forums/sh...d.php?t=255114
I got confirmation from Mike that there is no additional charge for the system to fit my Screw with the 6.5ft bed. The only additional $$ over and above the $430 list price was for shipping/handling.
Am I correct to recall that this kit is a direct bolt on and there is no welding involved?
Thanks again!!
Thanks again!!
Thanks again!!
Thanks again!!
