02 F150 Sport 4.6 Want Deepest Exaust
the pipes just end under the cab Were that support beam going frame rail to frame rail is... thats were my exhuast pipes Stop...they dont go all the way to the back....Wont lagh at you just a smile we all had to learn some time. But if you want loud thats the way to go....its got a nice deep rumble at idle too. Feel free to ask anything no one will make fun of you
Originally Posted by Typow07
I want the Best Sounding exaust i can get for my 2002 sport edition, i dont care if its too loud i will just have angry neighbors, but im not sure if roush makes a exaust for my year and also does a side exit or rear sound better?
another one: http://www.youtube.com/watch?v=vlxLCbPvSvM
I take it by exhaust system you mean just the cat back. The benefits are mandrel bent tubing which basically means, unlike the stock piping, a mandrel bend won't be "kinked" and will retain the full diameter of the pipe all the way through the bend increasing exhaust flow. No bottleneck. My theory is, if you're going to do it, do it right. It's not necessary though. I don't believe Roush makes a system for 02. Borla makes the Roush mufflers though so you can always get a Borla S-Type muffler. Borla only lists them in a 2.5 inch single in/single out design which would work nicely to replace your stock muffler since that's the stock pipe diameter but you will need an extension pipe since the stock muffler is huge and the S-Type is only 14" long. Magnaflow is another option. They make arguably the best flowing mufflers around. What you do all depends on your budget. If money isn't a big issue then get some long tube headers, ditch the 4 stock cataltic converters and replace with two magnaflow high flows and then run a new cat back system (pre fab or custom bent piping with your choice of muffler.)
