Corsa won't stay tight.....
I re-torqued the bolts on the system 3 times and I'm still having a problem with it working itself loose. Where the Corsa parts connect to each other just needed to be re-torqued once and they're still tight. The problem area is where the Corsa connects to the original system behind the cats. I've torqued that to the recommended 45 lbs but it won't stay tight. Seems like the whole system slides to the rear of the truck. The hangers haven't worked themselves through the rubber grommets, yet. Any other Corsa owners have that problem? One more thing, any tips on keeping the stainless tips clean and shiny? The road salt and cinders used to combat the snow and ice storms around here are really hard on them.
For SS tips it is always important to stay up on polishing them. Get a true, abrasive metal polish and really work on them about once a month or so in harsh conditions. When stuff builds up and sits it can sort of burn in and then you can't get it off.
As for the clamps, try a high-temp lock-tight?
Originally Posted by CRF250rider1000
use some red loctite or tac weld the nuts to the threads on the clamp
Also, those hangers aint gonna work themselves through the grommets on their own. Put a little dab of grease, or even vaseline, on the grommets and tap those hangers through. That actually may be the reason everything wants to back out, that the hangers aren't secure.
I'm going to be installing my Corsa system just as soon as the weather breaks. Are you saying that you're re-torquing the clamp at the convertor to 45 lbs, over and over, or that 45 lbs isn't enough to keep it on there?
Also, is red Loctite ok for hi-temps? I checked a bottle and didn't see any temp rating. BTW, they're all red bottles now. The medium adhesion version just has a blue stripe on the front.
The directions that came with my system don't say anything about re-torque to 65lbs. Hmmm. Have to give that a try. I have an intermediate pipe between the cat and the Corsa. That pipe is slid into the outlet pipe and held on with a single bolt factory clamp. No mention of loc-tite here either, just anti-seize.
