Might have made a mistake...
I made an offer on this catback on ebay to peformance peddler. the P/N is 16612 which is the SISO version. for whatever reason, the item description says Lincoln Continental but has the 16612 number next to it. did i screw up?
http://cgi.ebay.com/ebaymotors/ws/eB...D76%26_fvi%3D1
It says for 04 half ton to 06 half ton, u should have no problem but ask the seller to make sure.
Trucks & SUVs 04 1/2- 06 Ford F-150 Light Duty Cat-Back Exhaust System F-150 Light Duty , 4.6L/5.4L V-8 , EC-CC/SB , rear side exit , 3 SS tubing , 4 rolled/p-SS tip All Stainless Steel , Mandrel-Bent , Cat-Back Exhaust System With A Polished Stainless Steel Tip. MSRP $642.73 Trucks & SUVs 2005-2006 Lincoln Mark LT Cat-Back Exhaust System 5.4L V-8 , CC/SB , rear side exit , 2WD/4WD , 3 SS tubing , 4 rolled/p-SS tip All Stainless Steel , Mandrel-Bent , Cat-Back Exhaust System With A Polished Stainless Steel Tip. MSRP $642.73 CC= Crew Cab |EC= Extended Cab |SC= Standard Cab |SB= Short Bed | LB= Long Bed |P-SS= Polished Stainless Steel |SS Tubing= Stainless Steel Tubing. Fits Years 2005 ,2006
Originally Posted by TexEdition
The Magnaflow 16612 is what they list on their site for the SI/SO kit for the short-beds (5.5ft)..
If you can get that for a bit over 300 that's pretty good. Even if you do need to add a little pipe.
