Magnaflow High Cats Installed !Help!
#32
#33
Well, diagnostic test said bank 1 sensor 1 slow response so I went ahead and changed it this weekend. I've driven about 20 miles no check engine light but I still feel the hesitation and slight shutter from time to time. I assume the check engine light will appear and I'll have to get it checked again to see what it is. Anybody have any more suggestions?
#37
I also cleaned the throttle body yesterday. I replaced the PCV valve and had the PCV hose and elbow replaced a year or so ago. Yes, my mechanic has checked all hoses for leaks. All of this cleaning and hose replacing definitely needs attention on my truck. I appreciate you and others pointing these out to me because I didn't know half of these existed and needed cleaning or replaced. So you think my next step is cleaning the EGR right? I'll have to do a search for instructions on this. If you can pinpoint any other areas that might need attention pertaining to this please keep it coming. Thanks Again!
#38
Hope your issues are all resolved real soon. Not to hijack the thread but i'm also considering replacing my 4 cats with the Magnaflow rear 2.5" cats part #94006, 5.4l & 61k miles, as long as the O2 sensors aren't messed with I should be alright? I think I read somewhere in this thread that your truck ( Ford_Truckin' ) has 198k miles on it & thats probably why you have some issues with a high mileage block. Stuff goes wrong sometimes but 198k thats built ford tough
#39
Yeah, my 02s were not touched. They are in the same position and the same pipe as factory. But for some reason my modification turned my truck into a disaster. I'm trying to fix it without throwing parts at it and wasting a bunch of money. But to look on the bright side of things I've only replaced the starter and alternator and changed plugs/coils one time. So replacing and cleaning some sensors, valves, and hoses is only helping me to get another 200,000 miles out of her. I might go a ahead and replace bank 2 sensor 1 so both front sensors are new. There's a lot of components working together to make these things run and I'm learning the hard way.
#40
#41
#43
Yes, Initially I replaced the 4 stock converters with 2 Magnaflow High Flow Cats. Since then my truck has ran bad. Any help?
#44
Originally Posted by MagnaFlowRep
Well seems to me that you have removed the pre-cats up front which help heat up the exhaust. And since you removed them you rear cats are not getting hot enough. I bet the temps on the rear cats are not even up to operating temps. The cats should be between 900 to 1400 degrees. I would have that checked out. Have someone use a Temp Gauge on the outside of the cats and see what the temp is in the front and in the rear of the cat. Should be 150 to 200 degrees between the front and the rear.
#45
Ok, you said "cats should be between 900-1400 degrees" and then said "150 to 200 degrees between the front and the rear". These two statements confused me...please distinguish apart.
