Expedition Long tubes?????Which ones.
Ok I need help i have seen the 3 brands there are for long tube headers. I am leaning toward the pacesetters but dont know if the headers for the f150 fit the expedition. Can you guys help and give part numbers if possible. I have a 2002 expo with a 5.4l 2wd. Also I need a set up with cats. Its either pacesetter or obx the dynatechs are too expensive for me. Thank.
I just put the OBX headers on my truck. I used two #94306 Magnaflow cats as Troyer recommends to replace the stock four. Sine you said it's two wheel drive, you shouldn't have a problem running the Harley/Lightning version of the OBXs. The headers are the same just the mid pipes are different. The Harley/Lightning mid pipes don't merge. They stay seperate and you can use a Magnaflow Y-pipe (#10778). I like that idea better than the 4wd mid pipes that go from dual 2.5 inch pipes into a single 2.5 inch pipe.
Originally Posted by bajabugn66
are those cats obdII compliant?
I got them from Troyer. I actually linked you in my last post. I did install them myself. What I did though, was take resonator and cut the short piece of pipe off before the resonator, the part that flares out. That is 2.5" outer diameter and the cats are 2.5" inner diameter so the flared part fits snug inside the cat, and then I just had it welded on so that the cat bolts up the same way the resonator would. Only problem is the cats are much longer, so you're going to need access to a chop saw or sawzall and a vice so that you can cut the mid pipes to the proper length. However, band clamps will not fit on properly because of the bends being so close to the joint. Horseshoe clamps are junk so I suggest getting it welded so it doesn't leak. I did install them myself. I also ordered stainless O2 bungs from my local A&A Auto for like $4 a bung and had them welded in when I had the flared pipe welded in.
what do you think about the 59956 Magnaflow cats i saw in another post where he cut enough to use the bungs in the obx pipe?
