Magnaflow kit Question?
Ok I'm looking to purchase a Magnaflow SIDO rear exit cat-back system for my 2008 F-150 FX4 SuperCrew. Question is, what's the difference in bolt on kits? A friend of mine is telling me bolt on kits aren't any good and etc. but I don't see what the difference is or could be? I'm looking into this kit. http://4wheelonline.com/Products.asp...oductId=100446
This is the same kit as what's avaiable on Troyer's website and can be purchased in one of his performance packages so I figure it would be my best bet. If this setup isn't any good please explain why. Thanks in advance.
I am looking at the same exact kit. Glad you asked this question. I have had both types. The answer I got from Magnaflow is that their kits are broke up in smaller pieces to aide in shipping. You could clamp it up and then go have it welded too. Just a thought.
i am also glad you asked this question because i was just about to ask the same thing.
i guess ill go to a shop and have them bend the pipes, ill just buy the muffler and pipes
but my question is what is the deepest most throaty muffler??
I had a 5.9 liter jeep that had a magnaflow and loved the sound of it but idk since i have 5.4 now
ideas?
ideas?
https://www.f150online.com/forums/sh...d.php?t=326057
Body Size?
Ok, I've somehwhat decided on joshmac's suggestion to buy a muffler and have a shop fab the pipes. Question is, with the Magnaflow SIDO muffler, what do the different body sizes contribute to? How about the inlet/outlet sizes as well? I'm assuming an 18" body would be quieter and a 14" body would be louder? Similarly from the inlet/outlet sizes, larger pipe diameter = louder?
I've more or less settled on this Magnaflow SIDO muffler with 3"inlet and 2.5" outlet. any comments?
Larger pipe diameter = less torque. You want 2.5" AT THE MAX. The 14" is the loudest 18", 22" are progressively quieter. With the SI/DO, the 3 in 2.5 out will work, I don't think they make a 2.5 in and out. But I would suggest goin with a true dual setup, and running a x pipe as well. If you can afford it, it will be the best system. I have the 14" and my vid is below, and there is another one in my thread if you want to hear it.
