2006 f150 4.6 throttle body
so you have a 3 valve 4.6 in your F-150?
I didn't think so
anyway, you have to get the parts for your truck as the mustang has a 3 valve and a different intake manifold and the mustang throttle body will not interchange. Also if you get a larger throttle body then you will need to port and polish your throttle body elbow.
you need to stick to the basics unless you want to go all out right away: CAI, underdrive pulleys, long tube headers, high flow cats, cat back exhaust, E-fans and a tuner.
larger injectors, cams, throttle body should come later on.
I didn't think so
Incidentally,
I have an 08 4.6 and have added the S&B intake, and some other mods. It doesn't take much to wake the 4.6 but your money is better spent on other items unless your going to work beyond the TB. If your not going all out as previously mentioned, go onto other mods and leave the TB.
ok, sorry newB...
so true
