Why is every shop giving me a hard time?
Most exhaust shops do not like modifying the OEM cats due to possible fines if inspection & emissions is against cat modifications. I couldn't find any shop to do the work I wanted so I ended up cutting my rears and running pre-cats only. Keep looking hard and be willing to drive a few miles and you will in time find the right shop.
i think the super44 with maggy high flows might still be louder haha
edit: just looked under my truck and there is a sensor after the rear cat. so i do not see why they wont be able to just cut them out and weld in hi-flows and leave sensor in place its still after the new cat
well, i cut all 4 off mine and replaced with 2 94106 maggies, if the shop will cut all 4 off and let you replace with just 2 then i would do that, good/bad, better performance and mpg (i believe) and your truck will be louder/sound better
but if they will only cut the rear 2 off, then do that, either way replacing 2 or 4 will be a good choice
I had the same probs, went to 3 shops before the Midas guys said sure np. They cut off my old cats, installed my new maggie hiflows w/O2 bung on the cats, plugged my old O2 bungs. I asked for my old cats back, no prob. If you find a place to do this for you make sure you ask for the old cats back cuz you can take them to a scrap metal dealer and get some $$ for them. I got $200 for my old cats.
