Long tube question
Long tube question
Ok I just got my Daynatech Long tubes on and OMG these this are feaken lound. Does sound a little weird due to I am still running the Single exit exhaust. Mostly to keep it some what quiet which it did some what. I have never owned or driven in a vehicle with long tube headers so I have noting to comapare it with. It sounds like an exhaust leak but is doesnt. When you drive with the windows down it just sound like it it blowing the exhaust past the gasket but it is not. I looked and dont see any visual leaks. When you drive with the windows up with the torque converter lock and put the motor under a load it sounds like an exhaust leak. If you start it up cold you hear no leaks at all when I would usualy hear a leak. Is this just a noise that comes along with long tube headers or is something F'ed up with my truck. I am going to give the shop that put them on a call to see if there was anyting that might cause this noise.
You said u looked for a leak...put ur hand next to the head while the truck is running and see if you can feel it coming out. also dont forget after a lil bit of driving you will need to retorque the header bolts. what about what the LT's go into? could that be leaking? and i agree with darren get an aftermarket Cat-back the stock exhuast isnt ment to hold up with this much flow.
Sorry I should have given a little more detail, I have the full daynatech kit with LT headers,two HF magnaflow cats and meet at a Y. I have the Magnaflow single exit 3" exhaust. I am going for the sleaper look . I went to the shop today and they said that it is just the noise that headers make. Going from thick stock manafolds to thin wall header is going to alow a little more noise. It is a little annoying, I guess I will have to put a smaller muffler on .
Thanks guy.
Thanks guy.
I was not sure what my truck was going to sound like the headers and HF cats while still using the single exit exhaust. I have been yet to see or hear anyone running my exhaust combo. Still sounds a little weird but once you realy lay into it, it sound good. It is ALOT louder then I thought it was going to be.
its funny that u say that jbrew, i thought i had a leak cause i can kinda hear that tinny sound..huh..guess not
Sometime went by before I decided to try the wrap. That's what it took for me. But , using that wrap will eventually rust the headers - moisture WILL get in there no matter what you do. I don't care about that , but others might.
NO, there is a member on (shifty85) here that has long tubes for his 4.6 2wd. He is runing pasesetter long tube headers. The only down side is that I dont think anyone makes a Y pipe other then I think OBX. This is why I wanted the daynatech setup, because it was an entire kit and I did not have to get custom made.
