Which Magnaflow?
Old 10-18-2008 | 11:44 PM
al150's Avatar
Which Magnaflow?
Hello all. I have a 2006 F150 SCREW 4x4 5.4L. Currently has true duals with Flowmaster mufflers. I am considering changing to a Magnaflow. Also considering adding an Air Force intake system. Should I use a single Magnaflow and if so which one? I am looking for increased performance and gas mileage. Sound is not a priority.
Thanks in advance for your reccomendations.
Old 10-19-2008 | 01:16 AM
A 100% single system would be best for top performance. Being with dual Flowmasters I would imagine it speaks to you well, so you can handle some loudness, I would suggest the 11" body, or 14" body Magnaflow.
Old 10-19-2008 | 06:28 PM
al150's Avatar
Thanks Darren. Is the 14 inch louder than stock if I use DI/DO?
Old 10-19-2008 | 09:59 PM
Just about any aftermarket muffler will be louder than stock. The 14" DI/DO will for sure be louder.
Old 10-20-2008 | 08:15 AM
Mr. eXtreme's Avatar
Later today I am installing a Magnaflow 12258 (18x5x8)
But I didn't want it too much louder then stock or any drone...
Old 10-20-2008 | 08:40 AM
That muffler will be perfect. You will barely hear it inside even till it breaks in more, It wont roar down the roads until you give it alot of gas. I believe that you will be happy with the 18" body
Old 10-20-2008 | 08:48 AM
That's what I was going for!!!! Thanks for the feed back....
I figured it couldn't be to bad a choice being that's what Magnaflow uses on most of there exhaust systems...
Break in was another thing I took into account...
I was going to go with the 14 inch body but then I figured once it broke in it would end up louder then what I wanted... Just my taste though...
AirAid modular intake tube, K&N filter, Magnaflow Exhaust, Line-X'd bed and fender wells, 2.5 Inch AS Level Kit and 3 inch AS Rear Block, 1 Mile range Viper 5900 SST remote start and alarm system, JL Audio Stealthbox, JL Audio 500/1, JL Audio 300/4, Alpine Type-R 6.5 inch components in front doors, Alpine Type-R 5x7's in rear doors, Alpine Iva-w505, LOTS of Dynamat, 15% Tinted windows, Billet Grills in factory H-bar and lower bumper.
Old 10-20-2008 | 09:04 AM
Yeah, you will be good. The fact that you have dynamat it will block out quite a bit of drone. F150s are the quietest in-cab trucks out there.
Old 10-20-2008 | 09:56 AM
It's Here....
Guess what just came through the door...
That's RIGHT!!! My New Exhaust!!!!!!!!!!!
I'll post pictures once it's installed!!!
Here's what is in the box:
Only differance is my pipes are Mandrel Bent...
Old 10-20-2008 | 10:00 AM
Good to hear its mandrel bent. You dont want that crush bent crap. Have fun on the install!
Old 10-21-2008 | 05:25 PM
edgespeeder06's Avatar
wow thats the setup I want for my truck, how much did it run you?
Old 10-22-2008 | 06:32 AM
pullmeoverred's Avatar
al150, I've got the DI/DO 14" magnaflow, it sounds great. It's quiet on the highway and get nice and loud when you stomp on it.
Old 10-22-2008 | 11:35 AM
I have the Magnaflow 12258
And am very happy with it nice idle quite at crusing speeds and a solid roar when on the gas!!!
Old 10-22-2008 | 12:08 PM
MagnaFlow_Rep's Avatar
Former Sponsor
I am glad that you are happy with this muffler. We appreciate your business
Old 10-22-2008 | 10:54 PM
al150's Avatar
Thanks for the replys. Magnaflow 14 inch it is.
Quick Reply: Which Magnaflow?
