Roush Exhaust Problems
Old 11-07-2008 | 09:26 AM
ameration's Avatar
Originally Posted by Coke734
Before I seriously injure myself...
(The lower one, it's already half out... I might be too chicken to finish it off.)
Can I remove this bolt without unleashing a massive amount of potential energy?
I left mine on the wheels when I installed mine but I put a ratchet strap around there so when the bolt was removed, it barely moved. Then I just used the ratchet to tighten it up a touch to get the bolt bak in and once it was tightened down I released the strap.
Looking back, probably not the safest way to do it but it worked for me.
Old 11-07-2008 | 05:27 PM
VegasMarkLT's Avatar
thanks
Old 11-09-2008 | 12:53 PM
Coke734's Avatar
Well, I finally worked up the courage to pull the bolt... The key was to jack up the frame enough to take the weight of the vehicle off of the leaf springs, but still keep the wheel on the ground so that the weight of the axle was also not supported by the leafpack. Because I was jacking up one side at a time, there was a small amount of torsion on the leafs and that resulted in the bolt being a little harder to pull, but it did eventually come out.
Oh, and the exhaust sounds great, I can't wait for it to 'break in' with more use.
Old 11-09-2008 | 01:10 PM
Congratulations!
Old 11-13-2008 | 10:35 AM
Congrats man, enjoy the sound.
Quick Reply: Roush Exhaust Problems
