o6 cats
well on a 2006 i wouldnt cut the converters off, to new of a truck for that, you can get some 94106 hi flow magnaflow converters to open your exhaust sound up a little, the converters will fit right between the sensors, as in sensor, converter, sensor
but if you cut the converters off you will just replace the converter with a piece of 2.5" pipe and your check engine light will come on unless you get MIL eliminators, your just illegal then and you cant pass inspection or emissions
