air intake?
Old 06-24-2009 | 10:25 PM
wchamp7's Avatar
air intake?
ok guys i am wondering what air intake i should go with for the most gas and performance out of it. i just got my truck it is a 5.4L 2006 FX4. so i just want the most out of it for the money. oh and i am going to be putting in a chip latter on when i get the money. thanks for looking.
Old 06-24-2009 | 11:31 PM
Try the DWV intake, do a search. It is basically the same gains as a commercial Cia. However, you wont see much of a gain unless you have a tuner like a gryphon, xcal3 ect ect. A exhaust system helps too.
Old 06-29-2009 | 09:01 AM
bglass0905's Avatar
So do you have to get a tuner or a chip to adjust the lean in the truck. I am new to this and I guess I didn't read enough until after I installed Magna Flow pipes (Cate back) and the AFE Cold air intake. I could feel more power when I installed the Magna Flows and it didn't feel like it was bogging down when I stepped on it for passing. When I installed my AFE, I notice a big jump when taking off but when passing, it felt like it was struggling and it sounded like it was double the RPM''s than it was showing me. Sorry to take onto your post but i can't find anything on here that is telling me what i am doing wrong, and I didn't want to start another post. Can anyone tell me what i am doing wrong????
I have a 08 F150 Surper Crew 4x4 5.4l Flex fuel.
Old 06-29-2009 | 09:08 AM
personally I woulnd't add anything to a 3 valve without a custom tune
Old 06-29-2009 | 09:35 AM
It's dangerous to add a CAI to a 2004 or 2005 5.4. Not so much with the 2006 up. However, you just do not get much benefit from a CAI without a custom tune written to take advantage of the additional available air.
Old 06-29-2009 | 11:43 AM
bglass0905's Avatar
Does it hurt your O2 sensor and plugs because of carbon build up? I think I will pull it off until I get the tuner. Edge is the way to go or is there something easier to use or better? Let me know, Thank you very much for the quick responses
Old 06-29-2009 | 11:50 AM
No, there should not be any damage and no carbon build up. The problem with some of the 5.4 3v engines is that the CAI can cause them to run lean. Too much air for the fuel and that can cause internal damage, primarily at WOT.
The Edge has canned tunes which are written for the stock intake, so it will not help you with a CAI. Get a Gryphon if you like the monitor feature(I do). It is the same hardware as the Edge, comes with the same canned tunes, but can be custom tuned by www.powerhungryperformance.com. They are also the source for the Gryphon.
If the gauges in the monitor are of no interest to you, then you could also get a custom tuned Xcal3 from Troyer.
You really need custom tunes for a CAI to provide full benefit.
Old 06-29-2009 | 11:59 AM
Would I be ok with the DMV/Gotts, I do not WOT and don't reach high rpms. I am planning on the tuner next year (spring/summer)
Old 06-29-2009 | 12:02 PM
My advise on a 2004 is to not touch it without a tuner.
bglass0905's Avatar
The exhaust wont hurt the engine internally will it? Ok i will remove the CAI until I get the tuner, and thank you for the advice. I have to ask what does WOT stand for?
Old 06-29-2009 | 12:03 PM
bglass0905's Avatar
Old 06-29-2009 | 12:04 PM
WOT= Wide Open Throttle
A cat back exhaust will make no change on the engine, and does not requir a tune. It's only when changing headers or removing cats that you need to retune for exhaust.
Quick Reply: air intake?
