Water in exhaust
Normal.
When a Catalyst converts carbon monoxide to carbon dioxode, the by-product is water.
When the exhaust is hot, this water travels out as steam/vapor (which is why there is little carbon in modern exhausts as this steam cleans it out).
The water you see coming out is usually at idle or at startup when the exhaust is cool enough that the water is not turned to vapor. This is especially true at startup when you will blow out all the water buildup from the last run as the exhaust cools.
BTW - this is why all stock modern exhaust are some form of stainless - they all have condensation buildup that will rust out a non-stainless system fairly quickly.
Jax 150 is correct.
Incidentally when I install my exhaust systems I intentionally add a "bleeder" hole at the lowest point of the muffler to allow the system to purge condensation. The condensation also includes carbonic acid and other acidic compounds that eat or rust out the muffler and pipes from the insides. Most quality exhaust tips include a small "weep" or "bleeder" hole at the base tip to allow condensation to run out.
