Flowmaster dumped 40 series - Intake?
Old 07-18-2009 | 01:12 PM
houstontrueblue's Avatar
Which intake would work best with this setup?
Thanks!
HTB
Old 07-18-2009 | 01:17 PM
4.6 Punisher's Avatar
Any intake will work fine, but unless you have custom tunes, you won't get the most performance out of either.
Old 07-18-2009 | 01:38 PM
4.6 Punisher - amateur here - "custom tunes"? lol
Apologies!
Old 07-18-2009 | 01:54 PM
Like a dyno tune?
Old 07-18-2009 | 01:57 PM
Like a custom tuned programmer (PHP Gryphon, VMP Xcal2/3). These take advantage of the modifications that you have done to your truck and only work on your truck.
Old 07-21-2009 | 02:43 AM
nateinoc's Avatar
do you have to get custom tunes just for putting exhaust (flowmaster 2 chamber)??
Old 07-21-2009 | 09:16 AM
No, you would be all set. Only if you do an intake/major engine work would they be required.
Old 07-22-2009 | 09:59 AM
nateinoc's Avatar
thanks truckguy24, i just wanted to know if it was going to hurt the truck in the long run.. already put it on 2 chamber with turn down at the rear end.. tanks for a quick reply guys......
Old 07-22-2009 | 10:10 AM
np man. Enjoy it!
Old 07-22-2009 | 09:16 PM
nateinoc's Avatar
i'm lovin it maybe too much now i offer rides just to drive .....
Old 08-15-2009 | 11:34 AM
triton5.4FX4's Avatar
Do you have the setup already cause I am looking to do the exact same thing..dump a flow 40 series.
Old 08-15-2009 | 01:59 PM
Any enclosed intake will be good.
Old 08-16-2009 | 07:20 AM
hlbbig69's Avatar
Hey Guys
Just my two cents I had a 3" flowmaster cat back with mandrel bent tail pipe K&N fipk kit. Tthe truck did gain good low end throtle response but when it got close the peak rpm I would fall off alittle bit. Also getting on the freeway if you are not in the sweet spot for the RPM it wont kick down for passing gear. So I did some research and I have found that if you are not looking for wide open performance. Another words daily driving & you possable tow boat or trailer. Eventhough the tech guys tell you to go 3" if you put 3" pipe from the cat to the inlet and continue after the muffler to the tail pipe in three inch and oversixe the 2.5 muffler inlet and outlet so that it fits the 3" tubing I belive the the 2.5 muffler creates back presure on the motor and it seems to be as responsive as the three inch but has no power loss all the way through the power band and does not fall off at top rpm. Maybe it is just my truck and I live in Califorina. I am telling you it is a world of difference. More to follow on the gas mileage when I had the intake and the 3" flow desaster. I lost three miles to the gallon and I am not a heavy footed driver
Mark
Quick Reply: Flowmaster dumped 40 series - Intake?
