X Pipe vs. H Pipe
Old 08-19-2009, 04:58 PM
carlschmarl2's Avatar
Okay, X-Pipe it is. Does anyone have any suggestions on brand? I'd like to order everything from the same place to save a little on shipping...
Carl
Old 08-19-2009, 04:59 PM
migdaddy's Avatar
Old 08-19-2009, 05:02 PM
Originally Posted by migdaddy
F* me! I didn't realize X-Pipes are so damn expensive. What's the reasoning behind that?
Estimated Total $419.60...Not including a shop's labor charge and additional pipe sections...
Old 08-19-2009, 05:21 PM
openclasspro#11's Avatar
my x pipe was less than $80 for a 2.25" ss magnaflow unit
Old 08-19-2009, 05:29 PM
migdaddy's Avatar
are u going with 2.5 or 2.25 piping. 2.25 will be cheaper, but not much. its expensive bc ur paying for magnaflows name and its quality SS. u could get a $40 one on ebay
Old 08-19-2009, 05:55 PM
4.6 Punisher's Avatar
http://www.performancepeddler.com/se...=2&subcat=3111
Pick the one that has the correct pipe size. As a matter of fact, buy all the components you need from performancepeddler.com, after you reach a certain amount, shipping is free.
Old 08-19-2009, 06:26 PM
I priced everything out using PerformancePeddler.com. Apparently they do not carry Dynomax Mufflers. But everything else was:
Your SubTotal: $325.10 + Two (24215 Dynomax Bullets $39.95ea) = $405.00
Old 08-19-2009, 06:42 PM
2001 5.4's Avatar
H pipe would sound better and give a stang sound
Old 08-19-2009, 07:11 PM
MudTerrain's Avatar
Yes... No.
Old 08-19-2009, 07:48 PM
Don't forget using the coupon code "bestoffer4em".
Yes... No.
More like Yes... Yes. (but only if you have the correct mufflers!)
Old 08-20-2009, 07:20 PM
2001 5.4's Avatar
actually yea an H pipe will give that sound to a truck, like 4.6 punisher said. i have an H on mmine and it can really resemble a mustang when i hit it right
Old 09-12-2009, 07:26 PM
So I've decided to just remove the last 2 cats and run my setup from there. I ordered the X-Pipe, 2 Bullets, and tips. I then went to the local shop to see if they would do the work. They had no problem removing the rear cats, but they would have to remove my headers in order to weld the pipe after the first set of cats since they are so close together?! This doesn't sound right to me. In addition to that, they said that the cost would be too much and that I should just purchase a "cat back system".
So for those of you who have true duals installed/custom bent, how much did it cost?
I crawled under the truck with the guy when he was explaining it to me and there's maybe 3"-4" from the last cat to the O2 sensor. And it seems to me that any person with decent welding skills should be able to weld this.
At $70/hr the shop claimed it wouldn't be worth it for me to have them hassle with setup. Mind you this is a custom shop that does some very nice work.
Any suggestions?
Carl
Old 09-12-2009, 07:41 PM
migdaddy's Avatar
the shop is confusing. first off, you cant buy a dynomax bullet cat back. second of all, its cheaper to have a shop weld everything vs buying a kit. kits cost 600 bucks starting vs $70/hr x3 hrs=$210
2 dynomax bullets =$80
X pipe= $60
$350
basically half the price of a kit.
Old 04-21-2012, 11:25 PM
dave06ford's Avatar
I'm also looking to do the same sort of thing to my 5.4L...I'm all for whatever would help get me as close to a mustang gt sound as humanly possible. A buddy of mine has an X pipe set up and it's alright but he is still convinced that my simple SIDO set up sounds better. If I go with the H-pipe set up I will post a video in the coming weeks.
Old 04-22-2012, 12:05 AM
I remember this thread, back when I was the only one with Magnapacks. Dark days those were.
Quick Reply: X Pipe vs. H Pipe
