AF1 and Lean code
Running lean is very dangerous to your engine since it will cause pre-ignition than detonation runing your pistons, rings, valves, cams and eventually your engine will be torn inside and possible parts flying out of your engine. You need to balance your air and fuel mixture, that can be accomplished by a programmer like Troy, PHP or others alike. but the best way to get an air to fuel ratio that would be perfect to your mods is through a dyno testing. hoss55 is right, you should take that cai off and put back the factory one until you get your programmer. Good luck.
I have the 3" AF1 CAI (bought it shortly before AF1 went under). The reason I went with their smaller one over their 3.5" intake is because they said the larger would require a custom tune to prevent running lean--the smaller would not.
I do suspect, however, that you're running lean with the smaller one because the 04s/05s have been know to run lean from the factory. A CAI would just add to the problem. Definitely get custom tunes or take it off.
I had mine on for quite a while (with custom exhaust) and just recently ordered custom tunes for my truck (upgrading from Edge to Gryphon). In about a month I'll have the reassurance knowing I won't cause any damage. I suggest custom tunes asap--the AF1 is too good to take off.
