Throttle Body???? Help!
I have a 2004 F-150 Super Crew with 93,000 miles on it. A couple weeks ago it started giving me trouble when idling and even started quitting at red lights. I took it into a mechanic today and they said the throttle body is filled with crud and needs to be replaced. They also said I need a fuel system service to keep this from happening again. Total estimate came to $942. Seems steep. Is this right?
There aren't any sensors in the throttle body, just the drive-by-wire system. You can do all this stuff in your garage with basic tools and common sense.
Remove the throttle body and elbow off with a socket wrench
Remove the electronics off the side of the TB
Clean the TB and elbow with TB cleaner and a rag
Reinstall and go
The carbon buildup is because of the EGR system sending burnt air back through the engine. The whole fuel system cleaner isn't going to do jack ****.
Reinstall and go
