pacesetter long tube headers
#61
Yea, yea - That didn't help. Use a 6" 3/8 extension w/13mm socket. Don't connect to the ratchet yet, - take the extension w/socket and reach over top of the starter and find the top bolt. Hook up with it. At the same time, use a match book or folded piece of paper and wedge it under the extension to hold in place. Now attach ratchet and break it loose.
It's easier if you pull the header back down, - that way you can see the bolts on the starter and get your hand in there.
BTW- If you lift up off the mount, the firewall/floor will be in the way next.
#62
#64
#65
#66
i think these headers are just defective. the drivers header hits the motor mount a little bit i just realized that. and i gotta put another gasket on that side now and the morons at the exhaust shop welded the headers to the exhaust so i have to cut the exhaust just to get the header off and get a new gasket in there. i am having terrible luck. the gains were very noticeable but definitly not worth all the trouble i have been going through to get these things on. i still cant figure out the egr either. i got an adapter but the egr is at the wrong angle for it to work.
#67
#68
jbrew and shifty are good help, take their advise. good luck bro.
#69
Yea, those EGR's are a PITA. Two guys from this site set me up tho. User phil6608 sent me the piping and user delirium fished an adaptor for me from the scrap yard that matched everything up perfectly. Not sure how I would have got it to work without the correct parts.
_____________________________________
The motor mount:
What you might want to try, I would anyway - Is take the motor mounts loose AND the trans mounts. The motor may have sprung on the mounts or the passenger side isn't torqued. Taking said mounts loose, your engine and trans WILL move from right to left. You do this with a good size pry bar towards the rear of the trans. You'll be surprised how easy it moves, that may have helped on the install, I forgot to mention that... My bad.
The motor mount:
#70
The motor mount:
#71
i did take the mounts loose but there back on now. and no the way my truck it you cant fit the cats right behind the headers because of the crossmember so i dont have any now. and its pipe welded up directly to the headers. i should have known that was a bad idea. well a bunch of websites said they were for both 4.6 and 5.4 trucks. there the pacesetter 70-2226 ones. its a 3/4 bung on the egr. and its pointed at a completely wrong angle. does anyone think its possible they messed up making these headers? cuz thats sure what it seems like.
#72
#73
I can't recall were the Motor Mount is in relation, I'll go out and snap a pic if I have to lol. Let me see if I have one on line somewhere first. - Here's how the EGR bung should be positioned and I had a 4.6L EGR tube connected in this pic. I since changed it to a 5.4L set up (that's a couple posts up ^^^^^ there), but yours should look like this -
Unless you have one of these -
Not sure , some are different.
Yea, here's the 5.4L set up connected -
#74
Here's an online album -
http://picasaweb.google.com/jbrew393/MoreHeadersPics#
Yea, I'm a long way from the mounts, but I have a 4x4 and a taller block.
This album shows what I welded directly to the headers. This was right before I chopped the front of the cats off and welded in a 3ID Flange.
http://picasaweb.google.com/jbrew393...ingsUpHeaders#
