need some opinions on exhaust.
While we're on the subject, how much of a loss (estimate in #s) are we talking about? What would be the loss associated with going from 2.5" to 2.25" with everything else the same?
I'm just curious because my truck came with 2.5" duals on it so I have no idea how much it lost from the stock setup. Wondering if it's negligible or if it's only noticeable when say, towing, like Darren mentioned.
I figure you will loose a little in higher rpm, but I could be wrong... I still disagree with the sound. 2.5 does sound better!
Not trying to argue, just opinions...
Okay, hows this to throw a wrench in the works..
I've heard all this talk about either 2.25 or 2.5" piping...
My Maggie I just got is 3" in, 3" out, and i Plan on running 3" piping from the muffler back to the tip....how is the 3" piping going to affect power/torque/sound????
3" is fine for a single exhaust. If you have true duals ( dual midpipes ) you can run them too thick because the engine will not receive enough velocity to keep low end power strong. It will have to have more gas to make the power which strains the transmission and wastes gas. For your single midpipe 3" is absolutely perfect.
