Need Recommendation on exhaust system
Borla and magnaflow both flow damn near the same. You will see a little different tone between the 2 though. Magnaflow uses 2 types of packing in there mufflers. Stainless and rockwool. Borla uses 100% stainless packing.
IMO, the Borla will have a deeper tone and more lower frequency noise, where as the magnaflow will have more higher pitched noise. but will still have a nice deep rumble to it.
Personnel preference from here on out...
Go with the DI/DO for cost reasons. Dual mufflers for more interior rumble, and sound outside. The dual muffler setup would drone a pinch more.
http://www.summitracing.com/search/P...d=magnaflow+14
Tomorrow is my appointment. I called them up to tell them I want an x pipe installed, and they told me that the best way to go is with DI/DO with the magnaflow muffler with that has the internal x pipe. Should I push the issue of having an x pipe installed closer to the cats or should the DI/DO xpiped magnaflow be good enough. I'm more interested in power then sound again.
The y pipe has all ready been cut out, I was just going to go with what the shop recommended the DI/DO xpiped magnaflow. Would it be possible to have an x pipe put in close to where the y pipe was and use the DI/DO x piped magnaflow muffler or would that be too many x pipes?
