HEADERS? or OE manifold?
THanks for the input guys and sandy Just waiting on your driving review..lol
and Darrenws6 that would be probably around the $1k mark before headers..LOL
I've been reading all the headaches that everyone has been having with their install I might just have a shop install em...couple shops qouted me $400... ouch.. but i don't have a garage, or "ALL" the toold req'd. So 6-8 hours in this blazing hawaii sun might not be recomended...LOL
Nope
$400 Is very reasonable IMO. Now if studs brake it could go quite higher. I had two broken, one came out real easy with the right tools, the other side however, not so lucky. Took me about 8 hours all together with interruptions.
I would say more than 6-8 hours honestly. We took our time and did other things in between when we got too frustrated with it. We custom bent a wrench to use to tighten the header bolts.. helped A LOT.
Drive review... don't know about power yet... definitely sounds deeper and slightly louder. Do not know about power yet as it was raining and I couldnt really floor it or anything. I need to look at where the collectors bolt to my Y-pipe... have a small leak it sounds like. Also you can hear more "noise" due to them not being as the cast manifolds.
After more driving I can say there is a noticeable quicker response but overall power is minimal.
I had to tighten the ***** out of the Y pipe to manifold bolts.... I mean to the point I thought I was going to break them. Long trailer pull tonight or tomorrow morning, we will see how it goes.
After towing 3 atv's pn a 6x12 trailer I can say that there is a noticeable increase in power. Towing on the interstate with the cruise controle set just above 65 I averaged 13.7 miles a gallon. I usually see just under 13 mpg when hovering right under 70 mph. We did have more weight on this trip though. Fewer downshifts and holds overdrive much better on the country roads we were driving on.
Took me 8-9 hours by myself to put long tubes on my truck, however I have aftermarket true dual and had to do alot of cutting and getting all that to hook up. whether you go shorties or long tubes the stock manifolds suck getting them out. Passanger side was worse of the two however. I didnt have any bolts break on my truck and I had to only remove a few studs on the pass side to get the manifold to come out. I used stock nuts/studs I didnt get any fancy locking bolts or anything.
Just curious, how much are the custom tunes? He already has a gryphon, and exhaust. Is he still looking at a grand?
