Your right, i just hope it dosnt go out anytime soon
i might replace it once i get 300,000miles because i did notice that she leaks oil from the bottom of the engine i think its the oil cooler line assembaly.
Well its 1 of 2 things. It could be causing a misfire so you will only be getting power from 7 or less cylinders. But most likely the compressor is going bad and is locking up, causing you to lose power. I would get a new compressor and chances are that would fix the power loss.
