Header Install Tips
Header Install Tips
Hi, I am fairly sure I will be buying the OBX kit soon, and have a few questions on the install. First off, which header bolts should I go with, and should I get different gaskets or use the ones that come with them? Also I will be doing the Gotts O2 mod, and would like to extend my wiring before hand, so if someone could tell me how much to extend it by, and on which of the sensors does it need to be done? Thanks in advance for any advice.
Jaret
Jaret
reuse the factory ones before you use the obx crap ones. I have reused them on a few different applications with out problems as of yet. You are extending the upstream o2 sensors which are the ones closest to the engine itself. I extended the ones on my buddies 05 I forget how much exactly. Measure it out after you get the headers installed to see exactly how much you want/need. The drivers side isn't that bad, the passenger side is a complete *****. don't be surprised if you have to unbolt the passenger side motor mount and jack the engine up to get enough clearance to fit it in there. If you remove the starter have fun trying to get the top bolt back in.
Good luck
Good luck
Hi, so I should just get some new factory gaskets? I should have mentioned the reason I am doing headers is that I have an exhaust leak on the passenger manifold gasket and I figure if I am going to all the work to change it I am not putting the stock manifold back on. What about new studs and locking bolts? thanks.
Jaret
Jaret
