True Dualed 5.4L w/stock cats?
2002 Supercrew 5.4L with all 4 stock cats still. It has a canned Superchips 91 octane tune and an Airaid intake.
I currently have a SI/DO cherry bomb extreme with 2.5" tailpipes and 4" tips exiting parallel to each other behind the passenger side rear tire. BORING!
I am pondering a switch to 2.5" true duals, crossover pipe, then two dynomax bullets, then exiting behind the rear tires at a 45 degree angle with 18" magnaflow rolled edge tips (yes Darren I have seen your setup...and I like it! ).
I am thinking Bullets because I want a straight through design, they are loud,...and they are relatively cheap. I have no idea whether an x-pipe or h-pipe would be better, but I know I need to balance the pipes out with one or the other. I have heard it will be louder with an H, but an X will perform better (don't really care with gives most peak HP/torque, just want it louder...which one will knock down less sound?)
I am going to set up the true duals and then if its not loud enough, I may swap in some hi-flow cats later. (I'm really not wanting to mess with the cats or headers though).
I am wondering if I will notice much difference in sound by making the switch, considering I will be retaining the stock 4 cats. Will it be louder at all then my current setup?
An increase in sound volume and deepness is my goal with the switch. I am bored with my current configuration and want true duals for the fun of it. Its my play vehicle, not a daily driver. I do realize that retaining the stock cats will still be the bottleneck of the system and hinder any performance I could achieve with going true dual. I'm ok with that as long as the sound volume/deepness improves.
I am tired of searching old threads for answers, I have been reading old posts for the last 4 hours. lol. I would appreciate a few responses to my specific scenario here. Thanks in advance for the help.
is this because I won't notice a difference in sound when I switch to true duals because of the stock 4 cats? Is that what you meant? Or, are you saying since I have stock 4 cats, I wouldn't be able to hear the difference between an X or H pipe?
Yeah, that's what I was going at. I suggest you remove the last pair of cats right from the get go. You won't need hi-flow cats if you keep your pre-cats, and they sound just as good.
ok, thanks for the clarification there. I called some local muffler shops and none of them will touch my cats. They all said they could true dual it for me if I brought in the x-pipe, mufflers, tips, I want etc...but they could not remove cats and they would not replace them "hi-flows" because that is not what they were equipped with from the factory.
So, for now...I am going to have them true dual it with an x-pipe, bullets, and the 18" maggie tips and see how that sounds with the stock 4 cats. If I dont' like it, I will find a local person who will weld in hi-flows or remove the back two cats on the sly. It's just that the shops around here won't do that apparently. boooooo!!!! lol.
but it will be louder than my current setup? even if I keep all 4 stock cats? I just want some assurance that it will bump up the volume/deepness at least a little before I pull the trigger on the true dual purchase.
Oh, and I called the shop that's installing and they said they wouldn't do it unless I ran mufflers. Bullets are ok, but straight pipe is not cool with them unfortunately. They said it won't pass inspection that way. Boooo!!! Oh well, I kinda want the bullets anyway to give it a deeper tone.
thanks
thanks
