Realistic hp gains with long tubes
Old 06-21-2010 | 04:28 PM
blk450er's Avatar
I have an 04 5.4 3v 4x4 with aK&N intake, 3" magnaflow exhaust, and a gryphon with custom tunes and was wanting some more power for towing. I was considering re-gearing until I had seen how much $$$ it was to put in 4.10s or 4.56s and thought I would look else where for now. I had been reading a little about headers and for the hassle of swapping out the stock manifolds it would be best just to go ahead and get the long tubes.
My question was if I went with the obx setup for example, how much hp/tq gains do you guys think that I would realisticly see with my mods? Also any mpgs? I dont really plan on doing anything else to my truck as for mods if that makes a difference.
Thanks James
Old 06-21-2010 | 04:30 PM
migdaddy's Avatar
There are plenty of threads asking your same questions. 30 hp/35 tq with a custom tune. Gears are cheaper than longtubes by the way.
Old 06-21-2010 | 04:34 PM
the OBX long tubes will run the OP about $575 and he can do the install himself, gears for front and rear after installation figure about $1200
Old 06-21-2010 | 04:37 PM
migdaddy's Avatar
didnt even realize he had 4x4.
Old 06-21-2010 | 04:43 PM
blk450er's Avatar
I was going to say I was pretty sure that the obxs were under 600 and my local ford garage told me gears were going to be around 2k!!
Old 06-21-2010 | 04:46 PM
blk450er's Avatar
Do you think that if I went to 4.56s it would feel like I put a set of headers on in the seat of the pants? If I did one or the other which would I feel more, if they would feel about the same then it would be a no brainer for the headers.
Old 06-21-2010 | 05:02 PM
Yes
4.6 Punisher's Avatar
You would feel a bigger difference with the gears compared to the headers.
Old 06-21-2010 | 06:04 PM
Drizzle's Avatar
you should regear...especially since you use your truck to tow. gears will be the most noticeable difference for you.
Old 06-21-2010 | 06:08 PM
And a major highway & average economy drop. It'll have some pull power though.
Old 06-21-2010 | 07:19 PM
SuperSlabCab's Avatar
I have 4.10's on my truck, and I'm wanting headers. The added torque will make a big difference in how my truck shifts, and cut out some of the lugging. Mileage-does suck, always has. Keep the engine at lower revs...improve mileage.
Old 06-21-2010 | 08:36 PM
sparkyb34's Avatar
i don't know how gears are on these trucks, but on my wrangler went form 3.07 to 4.56. Now I don't even use first gear except offroad. That thing will buzz all the way up to 80mph in no time. Offroad that thing can idle up just about anything, 4lo 1st gear and just let it crawl. I love the gears in it, it runs 3000rpm at 70mph. gas milage sucks on it but always has. I get 12 with 33" tires.
Old 06-21-2010 | 08:44 PM
Tumba's Avatar
Gears. Because the headers give more gains in the higher rpm range, and that doesn't seem to be what you're after
Old 06-21-2010 | 08:46 PM
migdaddy's Avatar
thats a huge jump in gear change. These trucks have either 3:55s or 3:73s. Jumping to 410s like i did well definitely increase the pull out of the hole, and with 4.56s youll get pulled back in your seat. Your MPGs will definitely suffer because your at such high RPMs all the time. at 65 mph on the freeway my truck is at 2300 rpms which equals 13 mpgs
Old 06-21-2010 | 09:40 PM
4wd150's Avatar
damn, after i got my xcal3 i could cruise at 65-70ish between 17-1800 rpms. thats with 3.55s and 33s
Quick Reply: Realistic hp gains with long tubes
