possibility of exhaust change after FRPP HOT ROD CAMS
Old 07-03-2010 | 08:11 PM
migdaddy's Avatar
so your torn between dumping it like in FX4life's and out the back with those huge banks tips.
  #47
Old 07-03-2010 | 08:22 PM
bankrpt's Avatar
Yeah I guess I'm sounding like a female that can't make their mind up sorry guys.
  #48
Old 07-03-2010 | 08:33 PM
migdaddy's Avatar
Do you want the tips hidden, or do you want fat tips comin out the back. You decide. Your still just doing a single Xr1 correct?
  #49
Old 07-04-2010 | 03:10 PM
avfrog's Avatar
I thought 5" tips drug...
  #50
Old 07-04-2010 | 03:14 PM
bankrpt's Avatar
They do drag but the banks dual tips use a oblong 3.5"x5" tip
  #51
Old 07-08-2010 | 05:25 AM
batn68's Avatar
You get them cams in yet? I have been wanting some thump for quite some time and might look into these just for the sound, not so much as a performance upgrade.
  #52
Old 07-08-2010 | 08:00 PM
IR0NS1N's Avatar
I dunno Id rather have a cam for function over just sound although sound is nice.
  #53
Old 07-09-2010 | 03:26 PM
avfrog's Avatar
^ Function? What exactly are you looking for?
  #54
Old 07-14-2010 | 07:40 PM
bankrpt's Avatar
I got a question could I go ahead and run true duals using my factory manifolds and when I do get my longtubes just tie into the existing pipes and what size pipe would you run? I know the 3.5" is to big because when it lopes it sort of sounds airy.
  #55
Old 07-14-2010 | 08:39 PM
Drick's Avatar
Long tube headers, NO cats. And 3 inch exhaust. That'll lope
  #56
Old 07-14-2010 | 08:43 PM
4.6 Punisher's Avatar
You can have true duals with the stock manifolds, but you have to rework the pipes with LT headers. Everything gets pushed back, so cats would have to be pushed back down the line and O2's will have to be extended so that they can reach. A custom tune is recommended since the O2 readings will be delayed.
I would recommend 2.5" since you've got the cams and you are planing on getting LT's. I would also recommend to get the true duals after you bolt the LT's on.
  #57
Old 07-14-2010 | 08:47 PM
bankrpt's Avatar
I'm going to be doing long tubes soon but I want to go ahead and do the exhaust with my factory manifolds for now. I want to use my factory manifolds come off of them with true duals with x pipe and two xr1 mufflers with the pipes coming out by the bumper
  #58
Old 07-14-2010 | 08:53 PM
Alright, that sounds good, but when you do get the LT's, you will have to get the whole front portion of the exhaust reconfigured.
  #59
Old 07-14-2010 | 08:59 PM
bankrpt's Avatar
basically everything from like a foot or so before the muffler will be changed
  #60
Old 07-14-2010 | 09:29 PM
bankrpt's Avatar
http://www.magnaflow.com/02product/02xypipes.asp
What's the difference in the tru x pipe and tru x crossover? Which would be best for me?
Quick Reply: possibility of exhaust change after FRPP HOT ROD CAMS
